Bosch 36V Sds replacement ?
View the thread, titled "Bosch 36V Sds replacement ?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
K
Kev the gas
I have a Bosch 36v Professional which is approx 3 years old. The full fat version not the compact.
Hardly used due to its weight with the 2.6 ah batteries. ( I have 3 batteries)
Any suggestions for its replacement ? My right arm is fecked due to 29 years fitting/selling boilers.
Max hole size drilling in masonry 10mm, wood 30mm.
Replacement must be light and interchangeable with other powertools, I currently have a mixture of Bosch 10.8v, and Makita 18v which is a pain with loads of chargers :angry_smile:
I use Bosch Multi construction drill bits in my Makita drill but it does struggle in hard bricks ect.
Is there a lightweight powerful drill out there non SDS ??
Kev
Has it lithium batteries as new ones are very light.
Failing that i have an 18v worx pro sds hammer for the lighter jobs.
I also have a 36v lion Hitachi hammer - great for putting 22mm holes in things !
The batteries are not Lithium, just checked again and are 2.6v.
The drill is fantastic, just as powerful as the 240v drill I have. The only down side is its weight.
Yeh old nimh batts are heavy. Screwfix stock the Lion ones. Pop and d ask for a looksy at one - then order online for less lol
For general work and hanging boilers etc my 18v all day long.
For putting in waste or condensate through brick walls my big boy comes out to play!
I am trying to find a combi drill to use most of the time, only getting the corded sds at the last resort.
I've been looking at the Dewalt 18v, my current cheap 18v old battery dewalt Combi drill will do 7mm in most walls fairly easy so the 18v sds should have no problem for hanging boilers rads and anything else
Yeh it will and the 4ah batts are good.
Its remarkable how much punch an 18v sds has. My worx isnt brushless (think the dewalt maybe) but has a lot of power
You said a cordless drill that does 10mm in masonry and 30mm in wood, - maybe non sds?
I don't think there is a perfect drill for this. Combi drills are good at most jobs but limited for masonry drilling. Hilti SFH 22A is a non sds 3 speed combi drill that easily drills those. I have it but it weighs a fair bit.
If a combi, as I suspect doesn't give you the power for some really hard masonry drilling, I reckon you need to go with an sds cordless drill 18 volt or more with interchangeable chuck so you can snap on a standard chuck for ordinary drill bits and hole cutters etc.
Or use two drills.
Combi drill will struggle like hell and blunt the dril bits imho with holes anywhere near that size as they are all percussion that i e tried over the years
Better off with a smaller SDS than a non-sds. If you insist on a standard twist drill then I would suggest the Hilti SFC22A
I've just bought a18 volt fuel sds. So far very impressed. Very light and very powerful.
Kev are you sure the batteries are not lithium, if I remember rightly the old bosch sds's with nicads were 24v and had the square batteries. the 36v's that came in 2 different sizes were always li-ion batts, firstly they were 2.6ah, then they bought out the 4ah...the larger "full fat one (gbh36vfli)" was a great drill, I still use mine most days, the position of the handle to the motor made it quite unbalanced for one handed use though, I assume this is why they have now followed trend and gone with a drop down motor design.
the new Milwaukee fuel sds's look great on paper, not sure how much I trust the amount of abuse these new brushless tools will take will all there chintzy electronics inside them compared to a good old brushed motor though, time will tell. Plus there now made in PRC, the older bosch's were made in Germany.
There's a firm I take my classic car to, they have loads of the brushless motor ones. Had them a few years, and recon there bullet proof.
That's the one, I've only charged the batteries about three times so far! But to be fair, I've only had it a few months. But if it carries on the way it is, I'll be chuffed.
Reply to the thread, titled "Bosch 36V Sds replacement ?" which is posted in UK Plumbers Forums on Plumbers Forums.
Kev the gas,
Kev the gas,
