Legally, I don't think it's not too late because the work was substandard but hidden on the day it was put in so you have a breach of contract claim (implied terms - standard of workmanship).
It's probably not worth the time or effort pursuing them just for this, however, do you really want to see how bad their second attempt is? For something this small, just get a proper plumber in or, if you have the requisite skills, do it yourself.
Whoever 'installed' that, certainly isn't going to give a flying kcuf about someone coming back to him about his 'quality' workmanship. Just get it sorted by a professional and learn from it.
  • Agree
Reactions: king of pipes
It’s probably a homeserve repair
Or I haven’t read the full story lol
We'll come visit you - when you're doing time for defamation 🙄
FWIW, my experience with the management of Homeserve is that their focus on the quality of what they do is extremely high - higher than the job cost in fact. #JustSayin😉
Lol, if I ever come across some of the repairs they’ve done again, I’ll put some piccies up
Reactions: Welder
I ended up repairing it myself
I know the compression joints are a bit amateurish but I was reasonably happy with my pipe bending. It'll be less likely to leak now.
Okay. Thanks for the tip.
While you're at it, I'd wrap a bit of felt insulation around where your new pipe is in contact with the joist. Also check there is enough clearance between the new pipe and the skirting board to allow repainting when you need to redecorate. It maybe okay as it is but the photo makes it look a bit tight to me.
  • Agree
Reactions: Pickwickpick
Is that your first attempt with a bender? Great work, although I’d remove them valves under the floor due to what has previously been mentioned and added to the fact that they are serving no purpose under there anyway. If you’re not confident at soldering you could use JG straights.
A damp wall and peeling paper led me to investigate the radiator on the floor above it. Lifting a floor board revealed a braided flexible hose connected to the radiator. This didn't strike me as standard practice not to mention the severe kink in the hose. However I think the small slow leak has been the result of the compression fitting joining to the radiator down pipe not being tightened enough.
Does anyone have an opinion on whether using braided pipe in this circumstance is a good idea? Should I replace it with standard copper pipe?View attachment 36514 View attachment 36515
very naughty centralheatking
mind you I had to do this type of temp fix late at night just to keep things going
