Bristan recessed shower too stiff
View the thread, titled "Bristan recessed shower too stiff" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
M
Margaret
I have a Bristan recessed valve shower. It was installed 11 years ago - but hardly used as the handles are far too stiff. I have now had the cartridge replaced - but no improvement. I have been speaking to a plumber who suggested it may be as well to replace the shower [which I am prepared to do]. The original shower is obsolete - but there is a ‘direct replacement’. The plumber is not prepared to take the job on. Is this a particularly ‘tricky’ job? I would very much appreciate you advise on the best way forward as it is frustrating to have shower that cannot be used. Thank you.
With a new cartridge fitted, I find it odd that it’s still stiff.
This leads me to believe that it wasn’t the cartridge causing stiffness but rather the way it’s installed.
The handle/knobs could be set slightly too far back causing rubbing on the cover plate/spindle covers.
I would test the handles for stiffness with the plate/covers removed before deciding what to do.
There may/may not be some adjustment if this is the real issue.
Reply to the thread, titled "Bristan recessed shower too stiff" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
Margaret,
Timmy D,
