View the thread, titled "Brp" which is posted in UK Plumbers Forums on UK Plumbers Forums.
brp
Hi all can you help i want to change my 1971 brass looking barrel shaped radiator valves to modern ones the pipework looks to be 15mm now will the new fittings fit my existing rads ( these are too from the seventys with roll tops ) ie: are they the same size ??
thanks for your help in advance.
most valves do swop over just check the valves are the same size some older valves were a bit longer meaning if theres no give from the floor you have to lengthen the pipe
Reply to the thread, titled "Brp" which is posted in UK Plumbers Forums on Plumbers Forums.
