Burner motor to Oil Pump Vibration
View the thread, titled "Burner motor to Oil Pump Vibration" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi
I've fitter new motor to Inter 2011C burner which drives Danfoss BFP 11L3 oil pump.
motor bearings are good fan rotates freely and without wobble. There's a vibration noise from the pump coupling area which I just can't seem to solve.
If I slacken the pump mounts and move it slightly noise changes but I can't seem to get it quiet.
Is there a trick to getting the pump aligned with the motor? Is the pump the problem?
Any advice will be much appreciated.
Andy
Not surprised the motor bearing are good if the motor is brand new.
Was the new motor an exact replacement?
I think I know what might be wrong, but you really need to get it done by someone qualified.
Analysers show up badly burning boilers.
Reply to the thread, titled "Burner motor to Oil Pump Vibration" which is posted in Boiler Advice Forum on Plumbers Forums.
Northers,
Best,
