The claim made by Adey is rubbish and I have tried my Magnacleanse with and without my Fernox P/F machine and the difference the P/F machine makes is amazining. Also the addition of the Magnacleanse to my P/F is amazing. They work very well together.
The set up above is the best and fastest way to flush a system that has a problem with sludge. If the system is mildly dirty then a flush through with mains water would do the job. With a proper powerfush machine it is the velosity of water and the option to change the flow direction at a pull of a lever to loosen stubben deposits that does the job properly. I have never used a vibraclean attachment and I personly think you are asking for trouble doing so. The above set up works best with the boiler on if posible. I use Kamco FX2 with the best results, I have tried Fernox and Sentilnel products and found that one best.
For an average property of 3-4 beds say 8-10 rads it is still a days work, I test and record the results for each rad as I go.
The other proplem that needs to be addressed when powerflushing is the reason the system go sludged up in first place and put it right, which is what I do. It could be the pump fitted in the wrong position or the feed and vent crossed over. This needs to be corrected or in 6 months the system will be a bad again.
I did a P/F at a property, the rads getting replaced ever 2-3 months because of pin holes. The customer said "powerfushing wont work, we've had it done before" I said well give it a go and we will find the reason why its happening as well.
So we started getting all the equipement out "what is all that stuff for? the previous plumber powerfushed without the need for all that stuff, all he had was an hose" she said
Any way job flushed and system changed to sealed with the adding of expansion vessel etc. 2 new rads fitted as pin holed. That was over 2 yrs ago and she has never had a problem since.
Sorry for the lenght of this post its turning into a mills and boon saga.
And I posted in the wrong thread! will repost in the correct thread
