Camray 3 boiler lock out
View the thread, titled "Camray 3 boiler lock out" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi
My oil boiler keeps locking out after running for 30/40 minutes! I then try to reset it but it won’t fire back up! I have to leave it for several hours before it will fire back up! Only to lock out again after 30/40 minutes!
The boiler has had a new nozzle, coil and pump in the last 2 weeks!
Any help or advice welcome
Just had a different engineer out and said it maybe overheating! Just had the inside vacuum out off all the soot etc and still locks out after 30 minutes
Also there is an orange/red dust left everywhere after being vacuumed out! Do you no what this dust would be and is it harmful as we have young kids
Is the actual burner locking out or the high limit tripping?
No not dangerous, but any decent engineer isn't leaving a mess.
Temp and boiler lockout aren't linked.
You said that it would take hours to reset, what was it doing when you pushed the reset. What noises was it making?
Could be anything. But nothing a decent engineer can't sort.
You can hear a sparking noise and then shuts off! I would upload a video but it won’t let me
Had someone back out and they changed the control box but didn’t work so put the old one back on! tighten up the terminals and it worked for 24hours now it’s gone back to locking out! Checked the terminals and there all tight!
Need to check if oil flow is good could be restricted so you get x amount of litres through then it runs out etc eg pipe kinked etc
Sounds like a mectron burner. You can hear it go through the ignition sequence and definitely no oil at point of ignition and locks out.
I'd first look at oil pressure whilst washing and also photo cell.
Reply to the thread, titled "Camray 3 boiler lock out" which is posted in Boiler Advice Forum on Plumbers Forums.
Dan2505,
Dan2505,
