PlumbBobBob
one thing i don't think anyone has mentioned yet(only skimmed) the two vents are going to the wrong tanks.
If there's little room in the cylinder cupboard, maybe be put a y plan in, give you a bit extra room as well as a little more efficient.
You will not be able to carry out the works completely yourself.
Alterations inside the boiler have to be carried out to convert to fully pumped, from gravity. This work involves opening the combustion chamber which is illegal to do unless Gas Safe Registered.
Regards
Kev.
Reply to the thread, titled "can i use old 1" and 1 1/4" gravity pipes when converting to fully pumped?" which is posted in UK Plumbers Forums on Plumbers Forums.
