Jennie
283
45
28
Hiya,
I'm running two plastic hot/cold 15mm pipes into an extension to feed a shower/basin/toilet/utility sink.
One of the runs involves an elbow and passover so the hot can run horizontally above the cold.
How much effort should I go to with this passover? I'm using plastic pipe with brass compression fittings (and inserts). Is it OK if the pipes momentarily touch, or should I perhaps do the passover in copper and keep the two pipes separate?
Thanks for your advice?
Jennie
You should try to keep the pipes apart otherwise heat will transfer to the cold, no one likes brushing their teeth in warm water. You should lag hot and cold to reduce the tranfer of heat.
Any plumbing merchant or b&q will have the correct pipe insulation its like a length of foam cheap and easy
