View the thread, titled "Can someone recommend a new thermostat" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
I wonder if someone can recommend me a new thermostat. Something cheap that I can just order online? I have a new wells mclain ultra indirect hotwater tank and the thermostat has givin me problems from the beginning. It would pop up err and i would need to reset power for it to restart but now just sits in err. This is a pic of the connections if someone could recommend me one I could order to replace? so much appreciated!
Being in the UK I'm not too familiar with Canadian electrics, but am concerned your photo shows a cable with Canadian mains colours (green-earth, white-neutral, and red-can be live), connected to terminals labelled 24Volts - namely a low voltage supply. I trust that brown sleeved flex is not mains? Assuming it isn't, could the source of the 24V be part of the problem?
I fear a typical thermostat is not going to be suitable for this application, you may have to get the exact replacement part for the tank, but first check, or get an electrician to check, it is wired correctly!
Was the thermostat new with the new hot water tank or was it fitted to the old tank?
If it's showing err(or) the most likely problem is the temperature probe that's connected to the top right on that printed circuit board and goes down into the hot water tank.
It's either faulty or by the looks of it the wires aren't fully in the connector.
It's 24volt and there will be a transformer mounted nearby.
If it is faulty the simplest way is to replace it with exactly the same model thermostat.
There's a video of someone fitting one on the link below,
Yeah it came with the tank for sure. I will check the probe wires to see. Thanks for the help
Reply to the thread, titled "Can someone recommend a new thermostat" which is posted in DIY Plumbing Advice on Electricians Forums.
