View the thread, titled "Cannon Precept gas fire manual" which is posted in Gas Engineers Forum on UK Plumbers Forums.
J
jaw
Hi
Does anyone know where i can get hold of a copy of the manual for a Cannon Precept gas fire. I've searched the internet without success. I am wanting to know the height and width openings of the fire into the builders opening.
Whoops, meant to put height and width dimensions for the builders opening
Do not have an uploadable copy, but opening dimensions are 460w x 630h if fire is to be screwed to wall.
Graham M, Thanks for the reply but I'm confused ! The fire is currently located via the fire inset at the back into the builders opening. The fire needs to be taken out and re-fitted into a family members house. When I visited the customer this morning I managed to get a rough width dimension for the fire inset (from underneath) of 305mm. Does the manual have give you any other dimensions ie for the inset part of the fire?
In order to re-install the fire it is a legal requirement to have a copy of the installation instructions so you will need to obtain a copy. I assume you are GSR or will be using a GSR installer.
Yes Mike I am a GSR engineer. Just cant seem to find a manual anywhere on the internet. Any ideas?
Reply to the thread, titled "Cannon Precept gas fire manual" which is posted in Gas Engineers Forum on Plumbers Forums.
