View the thread, titled "Cannot top up boiler pressure" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hello,
(Images removed. Please add them in a reply post directly to the forum.)
Please see the linked gallery with more details about the problem. Basically I can't figure out how to top up the pressure. Any help would be much appreciated! For some reason I can't get the imgur gallery images to stay in order but hopefully it still makes sense!
Thanks.
Hello,
Thanks.
I order to help you gravy you will really need to add more info normally a post like this with complete info will get 12 replies and you will be sorted out in under a few hours
centralheatking
I had more details in the imgur gallery but it seemed to get removed for some reason. I'll try posting it again
Are there any other details which would be helpful to know?
[automerge]1572699496[/automerge]
Please add images to the forum itself by using the attach file button. Thanks.
Ah, I'm new to the forum and didn't realise you could upload pics that way.
My boiler showing the low pressure gauge
An overview of the pipes below the boiler
A silver hose that I thought would attach to somewhere to increase the pressure
It doesn't screw into the fitting below it
It can't reach the fitting in the bottom right
A view of the underside of the boiler. Maybe there is somewhere here to increase the pressure?
Any help would be great!
The braided fill pipe has been fitted the wrong way round.
Check first that the non return valve is working correctly by opening the isolating valve on
the loose end of the braided pipe.
Remove the filling hose from the top after the check valve and fit the isolating end to the nut (close the isolating valve.
You can now fit the loose end to the lower isolating valve.
By opening the slotted valves you can now bring your system up to the required pressure.
Make sure both valves are closed when finished.
Check that the check valve is holding by opening the valve on the flexi eg the end that isn’t attached to anything
Remove the valve from the end of the flexi (the end that isn’t attached to anything)
Then put that end on the valve on the other piece of pipe and tighten up
You should now be able to fill your system
I'll have a firkin or two of what this one is on! 😛😛
What is to disagree with what Heliotrope Smith posted?😵
When I read your post comes out with the same problem he’s got now
I read it as
Check the dcv is working via ballofix
Remove compression flexi off the dcv
Install the valve on the other end of the flex where the compression nut is
Now install the other end onto the valve one problem he’s left with a female compression both ends like he’s got now as the flexi isn’t swivel / loose but both ends
Oh dear! Oh dear! This site is going to the dogs!
Get sober and read the post again!
Just need to reverse the filling hose!!!!!!!!!!!!!!!!!
Thanks Heliotrope and ShaunCorbs, with your advice I fixed it!
I took the fitting off the end of the flexible pipe, I'm not sure why it was on there.
Then it connected to the fitting below and I could increase the pressure.
It's in the green now! Thanks again!
That's a bit high if the boilers not running. Somewhere between 1 and 1.4 bar when the boiler is cold.
The boiler was running when I topped it up. However it has increased a bit further with the boiler being left on for longer and is now around 2.2 bar. How do I reduce the pressure?
Reply to the thread, titled "Cannot top up boiler pressure" which is posted in Boiler Advice Forum on Plumbers Forums.
