caravan central heating
View the thread, titled "caravan central heating" which is posted in Central Heating Forum on UK Plumbers Forums.
Y
yokerblue
I'm thinking of installing central heating into my static caravan using an old combi boiler I have in the garage.
To save on labour cost I plan to do all the heavy work myself, hang radiators, run pipes etc.
My question is, and it might seam daft, but can I use the one pipe to feed all the radiators in one continuous loop, example. 15mm pipe into the left hand side of first radiator nearest the boiler, then 15mm pipe from from the right hand side of the of the first radiator into the left hand side of the next radiator then repeat till I'm back st the boiler?
Obviously I'd have all the work checked by a corgi registered plumber.
But I'm just curious to know if this would work
Scott..
ok ok i get you just another person who doesnt want to pay a tradesman but wants his knowledge, fair enough ,just dont pm me insults, be a man.
To the op. I will not have you coming into my house, insulting my boys and acting irresponsibly.
You need a gsr in to look at your boiler. We cannot and will not give advice on the installation or repair of boilers for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a private message to either Gas man or Redsaw who will then check you and then give you access to the gsr private forum.
Thank you.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Thread closed.
Reply to the thread, titled "caravan central heating" which is posted in Central Heating Forum on Plumbers Forums.
yokerblue,
Dotty,
