H
hessyboy
hey everyone wounder if you could help.
Having problem with above boiler when using shower or opening 2 hot taps . When opening the hot tap downstairs shower starts to trickle out. The flow rate is 16 l per min at cold inlet at boiler hw draw off at boiler is only 10l per min the incoming mains pressure is suitable for the boiler anglian water have been and checked and said everything is fine. Worcester have said the boiler isnt big enough it was a 30 kw that was in so they said it needs 38kw. We now have a 38kw in the property and having the exact same problem anyone have any sugesstions?
Is the flow rate still 10Ltr/min with the 38kW? End of day a combi is a one tap boiler in my experience!
