Check valve / swing check
As the boiler is cct you only need one pump ideally a modulating pump is best and no there not m
Both the same
sorry @ShaunCorbs - what do you mean by "Check valve / swing check" ?
you comment "As the boiler is cct you only need one pump ideally a modulating pump is best and no there not m" - what is this referring to?
You will need a check valve to stop reverse circulating as you don’t have a zone valve you could fit a zone valve but a check valve / swing check is cheaper
The purge valves etc arnt needed don’t know why there’s a m on the end tho
2K
Boiler Advice Forum
Deleted member 126459
A
1K
Boiler Advice Forum
Deleted member 120897
