View the thread, titled "Central heating and boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Pea
I posted a question here about my radiators downstairs not heating up and would like to thank all who replied. See http://www.ukplumbersforums.co.uk/central-heating-forum/39854-new-boiler-problems.html
I have had a second engineer come in to have a look at the system and he got them working within an hour (after he found what was wrong). He has given me a report about why they weren’t heating up and I would like your comments as to whether I should seek financial redress from the original engineer and what you think of his work (I paid him £3k for the job which he failed to finish and he wants to charge me more – he is Gas Safe Registered – should I contact them about his work?).
The old boiler was a Baxi (gravity hot water system) the new boiler is a Vaillant combi boiler, the report states the old boiler (which I was told by the original engineer had been decommissioned) was still connected to the new system. This meant that that the new boiler was running around two loops, the first was the old loop to what would have been the cylinder and the second loop around the ch system. This meant that the boiler would shut down before the rads got up to temperature and restricted the flow around the heating system meaning the downstairs rads would not heat up as they should. Also the gas to the back boiler had not been capped off.
He fixed it and confirmed that flushing the system for a second time and changing the pipework would not have solved the problem – the original ch engineer was charging us for a second flush and wanted to change the pipework as he said this was the only way to get the downstairs rads working. He wanted to charge us another £500.00 for the second flush and replacing the pipework…..
I know it’s a long post but I would be really grateful if you could let me have your thoughts, thank you.
i dont know where you would complain or send a report.. however this is very bad practice. someone needs to know.
It's not bad practice, it's terrible practice! Go to your cab armed with your paperwork, invoices, quotes etc and this report and see what they can advise.
My Mrs who just had a squint said - trading standards
Father Xmas
Thanks for your replies so far, I know nothing about central heating so I don't know if the work he did was just plain wrong even to the point of being dangerous. The gas not being capped off did give me cause for concern but I have to admit but that I am not sure if this meant it was just another little problem or whether it was actually dangerous.
The gas not capped off to the back boiler is a very serious breach in my opinion. It should have been decommissioned properly. I would contact Gas Safe with your concerns as well as trading standards.
Reply to the thread, titled "Central heating and boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
