Central heating and pipework issus all over newly bought house.
View the thread, titled "Central heating and pipework issus all over newly bought house." which is posted in Central Heating Forum on UK Plumbers Forums.
If you add a good quality system cleaner (I Only use Fernox Product's) F5 , then run system it will start to dislodge sludge, But you will need to clean the filter every couple of days, but first remove rads and rinse though with hose, bit of a time consuming job but if you are looking to save money that is the way to go, DIY. Did you say that someone quoted £500 to replace pump and power flush system ? if that's so you need to get him round asap, You need to find out if you are in a HARD WATER AREA, as you may need to add extra chemicals to treat system.
Sorry mate, I responded to that above, but not clearly enough. Yes I am in a hard water area.
After balancing the radiators the house is much warmer, I would say every rad is very hot for the top 2/3rds, the bottom reasonably hot. The best way I can describe this is they are barely touchable at the top but you can hold your hand on them at the bottom, but still hot.
So perhaps thats not too far being reasonably efficient, but still needs some longer term remedy.
Right now perhaps I need to concentrate on sorting the boiler
(see video link).
I think the first step has to be to try and replace the CH pump.
Kev you have been told what to do mate your magna clean will catch any debris on its way back to the boiler but it's not there to clean the whole system out , drain down get your Adey m+3 cleaner in the system if that what you want to use and let the system run with the old pump for a week , drain and flush out , change the pump now add inhibitor Adey m+1 refill the system and vent out run the boiler job done
Reply to the thread, titled "Central heating and pipework issus all over newly bought house." which is posted in Central Heating Forum on Plumbers Forums.
KevRusski,
Dotty,
