E
erpkid
Enlighten me?
Google it. You will see how it relates to your current layout and what you need to do. Forget the bypass bit as you are Y plan though.
Enlighten me?
Brilliant, that makes perfect sense now. '5' is definantly in the wrong place. I'll move somewhere around point 2 this weekend and let you know how it goes.
I'll also confirm cylinder flow when I get home, so flow should go in the top and out bottom, is that what you are saying?
Co's I would have thought the other way around, my thought is hottess water should enter bottom first?
turning off towel rad wouldnt stop heat getting to other 7 new rads so look at where u label 4 and ya can clearly see that , erpkid solution is correct
Should have read the last but one post first!
dont they taech the 3 tee rule at college now or is it just combis :8:
Its seems to me you have plumbed it in wrong and plumbed/wired in the zone valve wrong.
I take it your a Diyer?
I posted a reply and then realized that you had already done what I had recommended, so my post was redundant. I have edited my post to, hopefully, make it clearer.Sorry, I don't understand last two posts, secondary circulation is now fixed by erpkid solution.
