F
fluidthegreat
He pump has gone and needs replacing. It has a celsia tf110 230v-50hz. What grundfos would be replace this please. Ive seen grundfos ups 15-60 pump 96281473.
You can still fit the ups chris, I rang up grundfos the other day and they said all the regs have done is stop them producing them, so sooner or later they'll run out and we won't have a choice.
And you still will be able to buy them, just only as a spare part (until 2020)
I'd be looking at fitting the equivalent Lowara though. Grundfos have got silly expensive.
Mike what lowara would be ok to use please. And what sort of price. I only know a little about plumming :0)
When you say ages croppie you mean years & years, in fact over twenty years !!Been using smart pumps in the commercial sector for ages now. Yes some can be tricky to set up, especially those with external inverters, but the money saved in the long run pays dividends!
You can not install this type of pump any more ! Under the euro pump directive you should use an energy efficient type such a the Alpha L & you would be mad not to the running costs are a lot lower than the old 15/60 ups
All true I know tamz but more to them than just electrical savings if people would just spend the time & have a look.You can Chris if you can continue to get them. There is so much misinformation around it is little wonder people, even pros get confused.
In the real world Mrs Noheat wants it fixed.
She rings you for a price. You say sure a new A rated pump that will save you 20p a week on your leccie, supplied and fitted for £200
She rings the next guy who says no probs i'll fit you a pump (any pump, myson, screwfix shyte) for £150.
She takes the £150 offer and he got the job and made about £50 more than you would have at your £200 asking price. Her heating is working and she couldn't care less about 20p a week and if it breaks down again 2 years later such is life.
That is the reality i'm afraid, no matter what some bureaucrat says must be done to save the planet if indeed it really needs saving.
Devils advocate :smile:
