sputnick
Hi all so I'm having nightmare with a customers boiler. Intermittent fault on CH hot water works fine every time. No fault lights, so rooms stat calling for heat ,clock on, pump runs and that's it. I have checked both flow and return thermistors both have resistance within the range in book (about 6). I've checked that there's 240v on electrical block from internal timer on all relevant terminals. Boiler works fine for a few days and then stops and won't fire up on heating but never goes to lockout. Motorised valve head has been changed and made no difference. Occasionally boiler will fire up but then goes out after 20 seconds again only when heating is on. So does anyone have any suggestions I'm struggling as it rarely goes wrong when I'm there. I thinking pcb but would like a better diagnosis if poss. Cheers Nick.
