Chaffoteaux & Maury Boiler Problems
View the thread, titled "Chaffoteaux & Maury Boiler Problems" which is posted in Boiler Advice Forum on UK Plumbers Forums.
F
Foodface
Hi all, got called out to a boiler service on a Chaffoteaux & Maury Britony system 2 and been having serious problems as the installation has been failing the tightness test. After some investigation and consultation with the customer I decided to pursue a certain course of action which did not remedy the situation, after further investigation I have deduced that there is a leak with the boiler. As when isolated the tightness test passes no problem. I've done all the usual things, tightening every nut on the gas line after the isolation point but to no avail.
My thinking is as follows that it's either:
a: A faulty gas valve letting gas through
b: A problem with the factory assembled gas pipework components within the boiler
I've rang every number for Chaffoteaux and Maury there is and been on hold with Ariston for nearly an hour, so just thought I'd throw it open to the forum to see what peoples thoughts are on the matter.
I've since ID'd the installation with owners consent and disconnected the appliance.
Do you have a gas detector? could be worth putting it in the flue with the boiler off to verify that the gas valve is passing. You could even get out there and give it a sniff lol
The drop is not permissible, but no smell of gas (which is irrelevant due to the size of drop)
Flue is on the roof but could get my sniffer in at combustion chamber poss to see if it is passing.
Thanks for your responses.
IF your parts suplier will lend you a gas valve it would be worth taking one along next visit, otherwise checking inside the chamber will verify the gas valve is faulty yeh?
Reply to the thread, titled "Chaffoteaux & Maury Boiler Problems" which is posted in Boiler Advice Forum on Plumbers Forums.
Foodface,
diamondgas,
