changing a toilet syphon
View the thread, titled "changing a toilet syphon" which is posted in Boiler Advice Forum on UK Plumbers Forums.
morning all just popped over from the tiling forum, since friday ive been trying to replace the syphon on my close couple toilet but it keeps leaking, ive bought a new close couple toilet kit but the one i took off is 50mm and it seems i can only get a 55mm kit? will this still do the job? plus i think i may of left a rubber washer off, should there be a washer where the metal bracket meets the bottom of the cistern? allso the donut rubber that came with the kit is far to big for the toilet pan do they come in different sizes? thanks in advance, and i dont think im going to be adding plumbing to my CV in a hurry....lol
i use a bit of silicone between pan and metal plate, no need for washer. yes donuts vary loads in shape and size and materiel. you should be ok...........
Rubber washer between syphon and cistern, did you do-up back nut ? if you still have old donut washer reuse that with some silicone, some of the older WCs had large sponge type washers. Welcome to the world of Plumbing.
No No No I hate seeing syphons basin wastes etc siliconed in looks like a DIYer has done the job.
Silicon is for sealing around your bath/basin etc not for anything else dont silicon the syphon in as if you ever have to change the syphon again it will make it harder as you will have to scrape all the silicon off. If you must use something use plumbers mait
I'm with kay jay on this a smear of silicone between cistern and plate. No silicone on the donut.
those rubber donut washers that come with the kits can be a bit of a nightmare
you can buy the foam donut washers online which is the only place i can find that sells them
try toiletspares.co.uk
hi all, sorry but went with the first reply, had to get the toilet back on, and used silicone, and i reused the old donut as its half the size of the new one and cant see as it will fit, did it this morning and turned the water back on a couple of hours ago and so far so good....
thanks for the replys, whenever i attempt any plumbing i allways seem to get leaks, think i'll stick to tiling...:wink:
Foam washers are far superior as they compress much better. Get them from Plumbcall in Leeds in both sizes.
[DLMURL="http://www.plumbcall.com/product_489-1-45_Doughnut-Washers.htm"]Doughnut Washers - Toilet Accessories - PlumbCall - Plumbing and Heating Supplies In Leeds and Online[/DLMURL]
I actually prefer the rubber ones. Foam doesn't exactly fill me with confidence. Removed too many that are sodden wet because its porous and though bog doesn't leak the cc plate gets rusted and bolts need to be cut off.
Most toilets now come with cistern bolts and not a plate. Some of these rubber donut kits you buy, you'd need a torque wrench to compress them! I like the good quality foam ones, that is unless the syphon has a very short tail which in this case, they will leak.
Bolts should be stainless steel to prevent rust and I change any that are not stainless steel to stainless steel bolts, nuts and washers.
Reply to the thread, titled "changing a toilet syphon" which is posted in Boiler Advice Forum on Plumbers Forums.
Andy Allen,
Guest123,
