Changing of radiator valve!
View the thread, titled "Changing of radiator valve!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
peteeyres
I'm changing a radiator valve, I'm hoping the nut already on the pipe will thread onto the new valve, if so how is best to get a good seal around the old olive? PTFE tape maybe? Just I can't change the pipe because minimum bit coming out of the wall already. Help please!
PTFE is fine but usually you can get away without using any on the radiator. If you're taking the valve off the pipe then you need to drain the system (or get very wet which is not recommended). If you're draining the system then you can change the pipework as necessary and will find it easier to have a good join to the pipe and radiator.
There isn't much pipe to work with so that's why was hoping to get away with the olive an nut that's already on the pipework!
So if I wrap PTFE around the olive afew times it should hold well, it's on the flow!
Yes, but before that stage you need to drain the system. As soon as the valve comes off the pipe you'll have a spectacular indoor water feature unless the water's drained off.
Or use pipe freezing as a plug for 30 to 40 minutes - works well and then just top up and balance
i don't think there is enough space to freeze the pipe from what the op said. i would use an olive remover and start from scratch with new olive and nut.
If I unscrew the thermostat (top White part) does the valve keep flowing? Well it seems to, is the the valve broken or is it ment to be like that?
yes the valve keeps flowing it is meant to. what you should use is a decorating cap which is basically a plastic cap that screws on in place of the thermostatic top. if you haven't got one (you get one with the thermo valve kit) keep the thermostat on the valve but turn it right down as far as it will go this will stop the flow. what system do you have? combi or normal boiler.
as above in regards to taking the thermostat head off
If the decoators cap is missing you could try and place a 5 pence piece in there
but best be is do it properly, drain it down athen refill with a decent inhibitor
HOLD ON!!! if your changing the actual valve then closing it will not help you in the slightest as youll be undoing the nut between pipe and valve NOT valve and rad nut, so youll need your snorkell.
drain system down that way youll be dry if nothing else.
its always better to be safe than sorry.
Well at first it was just to take the radiator off but then we found out the valve was broken so yes then I had to drain the system down to change it!
Reply to the thread, titled "Changing of radiator valve!" which is posted in UK Plumbers Forums on Plumbers Forums.
peteeyres,
peteeyres,
