View the thread, titled "Cheapest lightest boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
southcoastboile
Doing an LPG boiler and ordered an alpha because it was cheap with a 5 yr warranty which is what the customer wanted. It's really heavy though so not sure if we can hang it.
does anyone know a light cheap boiler that will work on LPG without new injectors that has a 5yr warranty?
It's in a mobile home so the walls are really thin and apparantly it's quite a heavy boiler
Unless it's a water heater then most combis are heavy so best to strengthen the wall it's going on or add adit iona framing to cope with weight. For a motor home if looking cheap then a Ariston are cheap and probably lighter but poop boilers . Vokera mynute boilers like these are smaller , cheaper boilers. But not quality boilers they are lower end of the spectrum.
When I was looking at putting one in my mobile home I found the lightest was worcester junior. But even then I was going to strengthen the walls as they are only 1/4" thick boarding at best.
Reply to the thread, titled "Cheapest lightest boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
