Getting 240 on the white when calling for heat. 240 goes when demand is turned off. That's what I should be getting?
Thank you for taking the time to read the thread and reply ShaunCorbs.
Thanks for everyone else's replies.
I do that on a boiler change, as I change components also. Good idea to so more often though to make sure it's correct.
Reactions: ShaunCorbs
OK have changed the 3 port this morning. Its now doing what it should, on and off for each demand.
Rads getting nice and hot.
HW getting through coil OK. Didn't get any water from the coil when disconnected and capped.
Hoping thats solved it.
Will find out today.
Don't know what else it could be if not.
The ball valve that time changed on the F and E a few weeks ago has been getting sprayed with water from vent at some point as theres dirty ch water marks all over the shiny brass.
Thanks for all the replies, I received a text this morning to say heating working a lot better and no running overflow.
Perfick.
Reactions: mfgs
