Chlorine filter under sink query
View the thread, titled "Chlorine filter under sink query" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi everyone,
I got the water tested in my flat which has high chlorine levels and I am going to get a under the sink filter chlorine remover fitted as I am sensitive to the chlorine levels.
My question is that the filter will be fitted on the kitchen cold water pipe under the sink but the same cold water pipe is also connected to the washing machine, when the washing machine is on will the filter still be used as it will be fitted on the same cold water pipe?
I have attached photos of the pipes under the sink and the top pipe is the hot water pipe and the one below it is the cold water pipe with the stopcock .
I would ideally prefer the filter not to interfere with the washing machine pipe but unfortunately there is just one cold pipe under the sink and the other cold pipe which lead to the kitchen tap are too short and the filter won't fit on them.
Any advice would be appreciated as I am in two minds to whether get the filter fitted on the pipe or have a under the sink filter which has a a separate tap for drinking water.
Thank you
hi, it is a drinking issue and not so much contact with skin. Every time I drink tap water I come out in hives and a rash, I got tested for it and the high chlorine levels were positive. Before I lived in another flat and it had very low levels of chlorine and I didn't have any issues with it, my body has changed since I had an accident and it isn't as strong as it used to be.
Any recommendations on which Brita water jug or water filter for taps as I have seen so many online but don't know which one would be best especially in reducing chlorine as that is the main issue. I have a single lever tap in the kitchen so a filter which fits on that would be ideal.
Thanks again
Reply to the thread, titled "Chlorine filter under sink query" which is posted in UK Plumbers Forums on Plumbers Forums.
BobbyJoe,
BobbyJoe,
