View the thread, titled "Coiless cylinder" which is posted in Boiler Advice Forum on UK Plumbers Forums.
billybongo
Hello all , can you tell me if going back in the day cylinders that worked of back boilers had no coil in other words the ho****er and the water from backboiler are the same .
A friend just changed an emmersion for is father in law and said this was the case , it also had some gravity fed rads off it , surely it would all scale up , just courious .
Billy .
and rot the rads and boiler, but they were thick old iron back then
Yes. They were direct and heated from a back boiler. They only did the hot water and the balck boiler was normally made of copper.
I will have to ask him how many rads and what there made of , i know he said gravity to rads as i asked if system had a pump . cheers all .
Reply to the thread, titled "Coiless cylinder" which is posted in Boiler Advice Forum on Plumbers Forums.
