View the thread, titled "Column radiator - how to tell top from bottom" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi everyone, I'm looking to fit a small Nordic 3 column radiator, but the red plastic bung that indicated the top has been removed along with all the others.
I can see straight through the opening on the top and bottom and the diverter is separate, not already installed.
In short, without fitting it, I can't see a difference between top and bottom. I don't know if the direction of the thread on the bushes could be an indicator? Two bushes are threaded anticlockwise and two clockwise.
Thanks.
If there’s no difference between front/back or top/bottom then just choose the best face to be front and the best edge to be top.
Before fitting make sure that the valves will screw in where you want them, in terms of thread direction.
Okay so it doesn't make a difference as long as I put the diverter in the right place? Thanks.
Reply to the thread, titled "Column radiator - how to tell top from bottom" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
Joined
Location
Liverpool
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
radiator
Cluney,
Cluney,
