combi boiler positioning
View the thread, titled "combi boiler positioning" which is posted in Boiler Advice Forum on UK Plumbers Forums.
L
leonardtax
Hello, I have an Ideal Mexico boiler in a cupboard under the kitchen tabletop. If I replace the old loft tank and upstairs immersion heater with a mains-throughout-the-house combi boiler can this new boiler be in the same position as the old boiler. I don't want to remove the upper cupboards in the kitchen. Thanks.
Not enough clearance for a top flue boiler. The only boiler I know that fits under a kitchen worktop withithin manufacturer's clearences is a gloworm flexicom as it has a direct rear flue. I have only fitted the heat only variant but I would think the combi version will be at least 700mm high so that leaves 200mm you would need to check. The only other option may be a floor mounted boiler but I am not sure of the flueing arrangements for these but I would think one would go try the Worcester highflow.
Get a fitter out to survey the job you may well find a combi in the airing cupboard will work since most of what you need is already there except gas.
Reply to the thread, titled "combi boiler positioning" which is posted in Boiler Advice Forum on Plumbers Forums.
leonardtax,
tackleburger,
