combi boilers choice
View the thread, titled "combi boilers choice" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Neither. Take a look at Vaillant.
I'm sure someone will be along to disagree 😛 However the amount of issues I come across with Baxi and Ideal I wouldn't be having either of them by choice.
Out of those 2 I'd go with the baxi. But I would also agree with above and go with a vaillant too.
What do you want from it?
Quiet
Efficient
Cheap to repair
No frills or lots of technology
Out of the pair , vogue.
Personally I wouldnt fit , either go Viessmann from our European brothers
Seems anlittle high on output what’s the requirement? If I was you I’d look into Vaillant or viessmann but depends on budget and if it’s for own use or rented property
The baxi platinum is a great boiler ones I fitted years ago are still like new.
Not a big fan of ideal. Vaillant I had so many problems with the pumps packing up diverter leaking and pressure sensors playing up that I got put off them and tried baxi been with them ever since.
It is each to their own though ask 10 people get all sorts of answers.
What's your flow rate like as a lot of people ask me for a 40kw but they only have the flow rate for a 33kw.
Let's be honest here it wont matter what brand you go for they all fall to bits with aplomb.
Imho you need to have it installed as per manufactures requirements otherwise you wont get a warranty or guarantee. That's the most important thing is how good your installer is.
For what it's worth having been an owner of various boilers over the years the worst I have had is a Worcester and the best I've had is the universally panned Alpha
This question pops up very often....and you have come to the right place for advice My friends will give you advice based upon their experience
and you will be advised well and with passion. I would
engage a really well endorsed
local gsr installer. Put your trust in them. Let us know what
you decide ....centralheatking
please can anyone point me in direction whats best buy ?
baxi platinum 40kw or ideal vogue max 40 kw
I don't fit many boilers these days but I was impressed with Viessman. Very good components on the 100 range.
I've installed a lot of duotecs which were bulky and noisy so I wouldnt opt for one.
Can't say much on the duotecs but the new 600 series is really quiet.
Another vote for baxi. Duo/plat are great boilers. Big and heavy but reliable and stood the test of time.
Vogue is a decent boiler but they’ve changed the blocks from brass to plastic which degrades the boiler massively in my opinion.
Not overly impressed with Valliant/glow worm
3.5 bar on incoming main doesnt drop
60l/min
I’m always reluctant to fit 40kw combination boilers, my opinion is that if you need 40kw of hot water output then you’ve chosen the wrong system.
Biggest problem with high output is often the gas service isn’t big enough. Many houses have inserted 3/4 inch gas services and simply won’t provide the volume of gas required. So unless you want your drive digging or live in a newer house, lower output.
Depends what your looking for really, bother with all makes of boilers but if you fit a baxi duo-tec or 600 its 7 years warranty and the platinum is 10 years so you shouldn't really be back at it in a very long time. The Worcester requires there own filter and controller to allow 5 year warranty. as said in a couple o previous messages, fitted the baxi 636 and it is really really quiet. But your choice though
I’ve got a Valliant ecotec plus 831 . Installed 2016. Already needed new diverter valve and water pressure switch. Unfortunately did not have a Magnaclean filter fitted until now (2019)which caused sludge to block up the water pressure switch. As a result constant F75 notification where boiler wold not fire on less than 3 bar. Installed new pressure switch and now firing on 1.2 bar no problem.
Unfortunately this is down to poor installation and not the reliability of the boiler, vaillant are a cracking boiler when installed correctly.
Intergas Eco RF - best technology on the market for a combi. Half the moving components of every other manufacturer on the market. 10 year warranty
Ideal Vogue Max - 12 years. Need I say more?
Don't you have to jump through hoops to get anything repaired under warranty with ideal?
Reply to the thread, titled "combi boilers choice" which is posted in Boiler Advice Forum on Plumbers Forums.
drainrod,
Jerry,
