View the thread, titled "Combi with UFH (no rads)" which is posted in Water Underfloor Heating Advice on UK Plumbers Forums.
Bit of advice needed. Searched but couldn't find anything about Combi's and UFH with no rads.
Customer wants to have a combi, UFH but no radiators. Is it a good idea to have a single radiator on the system to provide a heat dump? Or should an auto-bypass suffice? If an auto-bypass then close to the UFH manifold or close to the boiler?
If the combi is set up correctly, you shouldn't need either.
Unless all the zones are on actuators, but then why would that be the situation
Reply to the thread, titled "Combi with UFH (no rads)" which is posted in Water Underfloor Heating Advice on Electricians Forums.
