d welsh
I have a problem with a combo emersion economy 7 overflow leaking from feed tank at top,I reduced water level and replaced part 2 ballvalve, but 4/5 hours later overflow leaking again,cylinder has no makers name and is covered in fake lookalike leather cover,stopcock in kitchen has pressure gauge above reading 2/half bar,blending valve on side of cylinder Is oventrop manual,customer had new leaver tap fitted in kitchen 6/7 weeks ago ,I isolated hot feed to tap thinking cold feed was maybe bypassing thru in to cylinder then to tank overflow above but after 4/5 hours tank overflow leaking again customer had a bloke round from yellow pages and offered to extend overflow pipe on outside wall in to gutter for around£ 150' but this won't cure fault,she has individual basin taps and shower bath mixer any advice would be welcome
Sounds like it may be a thermal store rather than a cylinder. If so I'd go with coil failed.
