Coming into the oil side
View the thread, titled "Coming into the oil side" which is posted in Boiler Advice Forum on UK Plumbers Forums.
smtplumbing
well i had not planned to do oil, but I now have a contract coming up that now that i need my oil ticket,
Had a look over the jobs yesterday, few things stood out but totally not 100 percent, I no a few things about oil but I am certainly not a expert.
If an oil pipe runs externally on a outside wall which the copper and is covered in plastic coating is the oil pipe allowed to be covered eg External wall installation ( the tiger loop was not covered)
If you need extend the oil pipe do you need to re cover the copper or repipe.
If anyone was any information about oil either on here on book based i would be have to sort something out for you guys.
Am in the training center next week.
Any helpful tips welcome thanks guys
TBH, I am not sure. I don't think there would be any issue with casing in an oil pipe that has no joints on it. Any bare copper oil pipe outside should be just the same as a bare copper gas pipe - as long as it is not touching anything that could corrode it (walls, ground, etc) it would be fine. You could obviously push a sleeve over it first before connecting to it, or denso tape it. As you probably are aware, you are not allowed soldered joints on oil lines. If using ordinary compression you are supposed to use inserts to support the soft copper pipe, although many don't. Oil hoses are not to be outside boiler casing.
Oil pipes going underground need inside another pipe - I use the plastic coated copper oil pipe, but I also fit it inside a 25mm water pipe & bring that up each end above ground or floor level & seal outside ends with silicone to stop rain water entering it. You can use the special plastic oil pipes with their proper inserts but not allowed to inside buildings. KBB fire valve needs fitted outside as you know & I think the rules are that it has to be at least a metre from any boiler house.
Tigerloops have to be fitted outside any building, boiler house etc, but you can fit the Bio Tigerloop inside which you can put a 10mm copper vent pipe from the top of it to outside. More expensive but neater & no cost of an ugly box to cover it outside then needed.
OFTEC didn't really teach much in my experience & the rules are in the books.
If your worried about insulating the copper feed, there is no need.
Oil has to be -30 or something before it freezes, filters clogged with dirt and muck on the other hand do freeze, so keep them clean!
Reply to the thread, titled "Coming into the oil side" which is posted in Boiler Advice Forum on Plumbers Forums.
smtplumbing,
MarkOil,
