View the thread, titled "Commercial catering make up air ...." which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
dav
Could anyone navigate me in the right direction . how do you relate the free area of a make up air grille with the extraction flow rate of a commercial catering hood , or how do you calculate how much air will pass through a make up air grille in a commercial kitchen . its just its somthing i dont know much about . ive even asked comcat 1, 2 and 3 engineers and they say its a specialised subject . i know the 85 % mechanical make up air rule , but not sure how to apply .....cheers
if you have comcat you should know this!!!!
The mechanical ventilation is measured by cubic meters per hour and will be relevant to kw rating of the appliances
and dont forget about you interlocks!
hi there
how can anyone forget interlocks linked to absolutely everything boilers, fire alarm panels and about everything else.🙄
you can use all sorts of methods amount of people floor area and good old dw172 what would we do without it .
cheers
Reply to the thread, titled "Commercial catering make up air ...." which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Unsolved
dav,
maddfridge,
