Compression fitting advice
View the thread, titled "Compression fitting advice" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hello,
I'm considering fitting an isolator valve to 15mm feed to my toliet cistern. It would require cutting off an existing compression fitting for a flex hose, after which I'd only be left with maybe an inch and a half of pipe.
I've never fitted a compression fitting before, can someone please advise if I have enough room here to fit a new compression fitting?
Thank you,
Bill.
Reply to the thread, titled "Compression fitting advice" which is posted in UK Plumbers Forums on Plumbers Forums.
bill_hook,
bill_hook,
