Guest viewing is limited
Compression Fitting and BSP
View the thread, titled "Compression Fitting and BSP" which is posted in UK Plumbers Forums on UK Plumbers Forums.
steveal
I want to connect two 1/2" BSP flexible tap tails (cold water feed and side rinse) to a 15mm copper pipe.
I notice that when I remove the nut and olive from a 15mm equal tee, the tap tails fit perfectly (with their rubber washers) to the tee.
Is it, therefore, unnecessary to use 15mm x 1/2" connectors?
you can, but the ends of the tap tails with the rubber washers and 1/2" bsp threads is to ensure compliance with wras. you are supposed to screw them as you describe but onto isolation valves.
your better off using 15mm male iron straits i have seen a few diy attempts fail because the cone side of a compression fitting cuts into the rubber washer
well i havnt flooded a house yet by filing a fitting, altho i have found leaks where people have connected these flexible taps to ballafix valves or onto 15mm compression fittings, due to the cone cutting into the washer, tbh i try not to every use then, i believe they are a lazy option and look untidy, would much rather bend up a bit of copper with a tap connector 🙂
Thanks for the replies. Some comments:
The existing pipe work does include isolation valves (a short piece of 15mm copper away from the current 15mm x 1/2" connectors).
I spotted the possibility of using an equal tee, because the new taps are supplied with a NRV. The NRV is a short brass item with identical threads on both sides - one side for connection to the 1/2" bsp tail; the other supplied with olive and nut to connect to the 15mm copper.
I'll check the condition of the cone area and make sure it's flat.
Reply to the thread, titled "Compression Fitting and BSP" which is posted in UK Plumbers Forums on Plumbers Forums.
steveal,
steveal,
