View the thread, titled "compression fittings" which is posted in UK Plumbers Forums on UK Plumbers Forums.
K
kennymck001
changing my heating pipework from 8mm to 15mm and noticed the big price difference in compression fittings for example a reducing tee (22x22x15) can cost from £2 to £8 each , I know some are cheap brass and dearer ones are copper , but are the cheap ones ok or should I go half way , as I will be buying quite a few the overall cost or saving could be quite a bit..
cheers
remember not to use compressions where you cant access them, ccause they will leak/.
end feeds are only 30p each /.?.
Reply to the thread, titled "compression fittings" which is posted in UK Plumbers Forums on Electricians Forums.
