Due to lack of flush took out the syphon and found membrane split. So sorted out a new one Viva Skylo Dual Flush Syphon - https://www.toolstation.com/viva-skylo-dual-flush-syphon/p51299
Not having come across a toilet like this before, been cobbled together by some bodger 20 yrs ago.
In the old flush a 32mm pipe has been stuffed up and filled with gunk inside the 40mm thread of the flush mechanism.
All I am basically looking to do is get a a connector with a 40mm female threaded end to use on the outlet of above flush and something on the other to mate with 32mm pipework. I did think of cobbling together using a flexible but there is not much room. Most of what I have looked at for the flush end, 40mm , has either a standard 40mm compression fitting or just a male 40mm, neither of which are suitable to connect to the 40mm male thread on the flush.
Any ideas? Thanks
Any ideas? Thanks
