Boiler on the other side of wall A. B will be a washing machine. C will be a rad. Orange dotted line is a partition wall. All brick/block walls will be dot dab. Concrete floor of extension is 75mm deep on top of insulation, the rest of the room is suspended timber. Best way to get a 15mm cold water pipe from A to B. and also get two 15mm feed and return pipes from A to C. Not to bothered about the utility room but I dont want any pipes showing in the living room (living room is located from where the photo was taken) Wood floor will run in direction of that timber you seen on the floor.
Open to suggestions.
Ideally I want to channel concrete with two straight runs but I know this can be a minefield with Regs.
