Condensate pipe to thin air
View the thread, titled "Condensate pipe to thin air" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
On a bad day
I would say 'id' as obviously the boiler has been installed illegally by a unregistered,incompetent person,if they can not terminate a bit of condensate correctly(which by the way is part of the flue system,therefore in theory the flue is not terminated correctly)how they expected to carry out the gas side !!
on a good day
NTCS
I have mostly bad days though
:32:
imho
Suppose it is an assumption, but haven't you been back to or seen jobs you've quoted for and seen why it was cheaper. Things like above or incorrect gas sizing etc.
I'm a bit confused about this.
By "terminating vertically" do you mean it terminates straight up or straight down?
And where does it go?
As for everyone trying to classify it under gas regs, All the boilers I know have an internal trap(built in to the boiler) which stops flue gases escaping down the condensate.
So is condensate termination even covered by gas regs to give it an ID, AR, Ntcs ?
I thought that too. But an icos doesn't have a trap. Must be others. I think the c55 hasn't either.
It is effectually part of the flue system. So it does come under regs in some respect.
If it is cut off outside it is not fitted to standard so NCS.
There is a bit of a grey area on condensate classification though.
Recently I was advised by Worcester that the Greenstar I was at was NCS as 75mm trap in place and the condi terminates above an open drain bellow sink in a basement. With no trap would be ID.
Ok the condensate pipe ran vertically down from the trap, passed through the wall horizontally, then vertically down to approx 300mm above a paving slab. The condensate was and it appears has been collected in a bowl for a year. Hope they wasn't giving it the dog to drink!
I got told that awhile back that an install me and another fellow did got classified NCS because the condensate ran to the ground (outside) then terminated level with the ground..... It was buried and ran into a soak away -_- trololol
Reply to the thread, titled "Condensate pipe to thin air" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Backboiler,
rawr,
