condensate pipes
View the thread, titled "condensate pipes" which is posted in UK Plumbers Forums on UK Plumbers Forums.
G
gates1979
Is it possible to run a condensate pipe internal then out through the wall as im sick of it freezing up and having to mess about defrosting it to get my boiler up and running again. At the moment it goes straight out the wall as it leaves the boiler in 22mm plastic then goes up to 32mm outside with about 2m diagnal drop to the grid. Or is it possible to connect it upto the washing machine waste as the washer is directly below the boiler
it can go into the washing machine waste alternitavly look at trace heaters by doing a search on here
You could for the time being just drop it into the washing machine stack - later route it into any internal waste pipe - your right condense boilers are a dead loss in cold weather
centralheatking
Reply to the thread, titled "condensate pipes" which is posted in UK Plumbers Forums on Plumbers Forums.
gates1979,
Centralheatking,
