Barneyjoe
Can't see any kinks and clear pipe is secured so difficult for kinks to be introduced, but it may be blocked.
If the water is being pumped up but running back down as you say then EITHER the non-return valve is faulty OR the motor is now weak and unable to pump to the required height as it used to.
i put £100 that the clear tube is kinked
Sounds like the pump is shot and can't raise the water to the outlet if the boiler starts condensing and the pump can't handle it it will be all over the floor you will know.
Which isn't a diy job. could be anything from hex as haps said, to a dodgy pump.
You'll be needing a gsr.
If nrv at fault water will rise and fall, rise and fall all the time the pump kicks in.if nrv at fault then hose will have no water and it will over fill
You remember my original post?????
Ahem......
And while this is happening boiler will produce more condenseIf nrv at fault water will rise and fall, rise and fall all the time the pump kicks in.
Reply to the thread, titled "Condensate pump on all the time" which is posted in UK Plumbers Forums on Plumbers Forums.
