View the thread, titled "connecting a remote water supply to garage" which is posted in Bathroom Advice on UK Plumbers Forums.
I need to lay on a new supply to an outside tap on the house wall, and another which is about 30metres down the garden by the garage, the blue 25mm MDPE pipe run has already been buried in a trench leaving both ends sticking up, and a spur T'd off for the house wall tap. The house end is right by the point of entry and has not yet been trimmed off the coil. There will be a new rising main at the point where the garden supply enters the house, both the RM and the remote supply will come through the wall below ground level through an existing 110mm dia duct (soil pipe) which comes up through the concrete floor right by the wall of the utility room. The utility room pipework will then be copper with 22mm feeding the combi boiler, and 15mm to the existing cold water pipes. There'll be an RM stop tap inside the utility room probably fitted about 400mm up the wall, there will be another stop tap inside the room for the outside supply
The question is what is the best way to connect the garden supply to the inside pipework, and is a DCV on each outside tap sufficient? Also would I be right in thinking that the inside copper pipes for the outside taps should be 22mm rather than 15mm, to lessen any pressure drop issues? The RM pressure is 6bar. Sorry for the long post but the question is quite straightforward I hope. Cheers AJ
15mm will be fine for the taps. The DC valves should be fitted internally to comply with the water regulations because the valve should be protected from freezing.
Mike
Reply to the thread, titled "connecting a remote water supply to garage" which is posted in Bathroom Advice on Electricians Forums.
