connecting a test pump to 15mm pipe (air)
View the thread, titled "connecting a test pump to 15mm pipe (air)" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Scott_D
Subscribed
Has anyone got a simple way to connect an air pump to 15mm pipe to rig up a crude air test kit?
Jut want to check I dont have open ends before filling up on my own
I use my regin stand pump and rothenberger test gauge . Kop
Brass Threaded Hexagon Bush 1/4" BSP PM x 1/8" BSP PF
P/N 6617
Brass Threaded Hexagon Bush 1/2" BSP TM x 3/8" BSP PF
P/N: 0784
Brass Threaded Hexagon Bush 1/2" BSP PM x 1/4" BSP PF
P/N: 6621
High Pressure Test Point Nipple - 1/8" BSP TM
P/N: 21329
Brass Hexagon Reducing Nipple - 3/4" x 1/2" BSP T
P/N: 10596
Gas Ball Valve - 1/4" x 1/4" BSP TM x PF Lever Handle
P/N: 9632
Brass Threaded Equal Tee - 1/2" BSP PF
P/N: 6544
Brass Threaded Hexagon Nipple Brass - 1/2" BSP T
P/N: 6582
JG Speedfit Female Coupler - 22mm x 3/4" BSP F
P/N: 7092
JG Speedfit Push-fit Reducer - 22mm x 15mm
P/N: 7103
Then you just need a gauge with a 3/8 connection
Sorry for the late reply
Reply to the thread, titled "connecting a test pump to 15mm pipe (air)" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Scott_D,
ShaunCorbs,
