Connecting Evohome to Worcester RI for modulation
View the thread, titled "Connecting Evohome to Worcester RI for modulation" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Good afternoon
I am expecting delivery of the Evohome ATP926G3001 package this week.
Is it possible and how exactly can I connect the the Evohome system to a Worcester Ri boiler to convert it to modulization? Is Greenstar Ri Open therm compatible?
My understanding is I need to connect a Worcester Bosch EasyControl Adapter or similar bridge to the EMS on the boiler and to the BDR91T. Is that possible? I am also not 100% sure I can use a Worcester Bosch EasyControl Adapter for a Bosch RI boiler, what else could I use?
Thank you
Sorry to say you can’t as it’s a heat only you would need a system boiler
Hi, I am not sure I understand this. The Ri has an EMS plug and is able to modulate.
But not usable for control / not sense compatible
As you have a cylinder that needs to be kept at 65c
So if you wc / opentherm it regulates the flow temp this is no good for the cylinder
Also the easy control adapter is only compatible with combi boilers
Ignore the s plan part as that related to combi boilers s plan systems
My understanding is that most systems with a hot water cylinder already have it configured as a separate heating zone controlled by a motorized valve (e.g., a 2-port or 3-port valve). The boiler provides full power for the hot water cylinder when it's called for, bypassing modulation.
  • With OpenTherm:
    • OpenTherm primarily affects space heating and modulates the boiler’s output to match the heat demand.
    • When the cylinder demands heat, the boiler typically switches to full output (non-modulated mode) to heat the cylinder efficiently.
Evohome also has dedicated hot water kit (e.g., ATF500DHW), (I do not have this kit and currently have a wired HW wired thermostat), which includes a wireless cylinder thermostat and relay for the hot water zone.
  • Evohome ensures the boiler is fired at the correct time to heat the cylinder.
  • The Evohome Controller communicates with the OpenTherm Bridge to signal a higher output for hot water demands while continuing to modulate space heating when the cylinder is satisfied.
Is this not correct?
This Dutch product should work (Nefit OpenTherm EMS converter | Plugwise - https://www.plugwise.com/product/nefit-opentherm-ems-converter/?lang=en) with the Ri as long as the Ri using EMS version 1. Do you happen to know what EMS version is used in the Ri? However I have not thought about the effect of modulation on the HW cylinder side.
I don’t believe the ems port is usable it’s there but not fully built in
Also how does it know when the hot water is being heated it doesn’t, it’s a dumb (in wiring sense) all it’s looking for is 240v on the heat terminal
Also that bridge is for the Worcester compacts eg system boilers or combis
You will require a new boiler if you want to go opentherm eg Viessmann’s 4 pipe system or ideal vouge 2 switch live terminals
Reply to the thread, titled "Connecting Evohome to Worcester RI for modulation" which is posted in UK Plumbers Forums on Plumbers Forums.
diselsamm,
ShaunCorbs,
