Connecting to black rubber mains pipe
View the thread, titled "Connecting to black rubber mains pipe" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I have a cold mains in that is a black flexible rubber looking pipe. Please see photo 1. It is currently connected to a 22mm stopcock.
I’d like to send it 90 deg to the right. This is so I can lower the shelf above it and have the mains come in at a more convenient place. See photo 2 (with annotations).
What’s the best way to connect to this mains pipe? Are there any issues with this plan?
Almost certainly 1/2 in black alkathene.
If you want to shorten it down 22mm compression fittings with a 3/4 olive works well . You will need to reuse pipe stiffener/insert from existing fitting.
So a 2mm compression elbow with 3/4 olive then reduced to 15,mm and a new stop tap.
But go steady this can be brittle and snap on you depending on age and condition, in fairness yours looks ok. Need a copper liner, is probably one now that you could reuse, or plumbers merchants if not - don’t try and get away without it, even if last person did!
Reply to the thread, titled "Connecting to black rubber mains pipe" which is posted in UK Plumbers Forums on Plumbers Forums.
e5c3d4,
Ben-gee,
