I agree with Reg Man the system appears to not vented - maybe a dirgo ie non rtn
air valve might help - but how this stands with building regs not sure CHKing
No open vents or AAR valves. That won't help.
yes its probably airlocking as theres no air getting in behind the water plug even a 50mmm durgo after the pan would probably cure the problem idealy the four inch should go to atmosphere after the pan
Is it an old syponic toliet as prop can arise when the wrong sypon is fitted (need to keep the ball inside )
Has the sypon been changed does it look new .
bit strange how it's been working for 10 yrs then suddenly starts to block especially on the top floor of a high building is there prob in the floor below ?
