salinia
Just thought I would share this, I was asked to give my sister a lift to work this am on arrival I said I can smell gas. She said open that cupboard next to the cooker I think it smells of gas in there. I did it stank of gas, I pulled the cooker out gave it the bubble test it seemed to be leaking from the fitting on the back of the cooker I remade the joint tested again still leaking...on closer inspection I determined the leak was actually coming out of the side of the fitting..it was porous! first time I have ever come across such a thing in my limited expierience. Replaced the lot had it checked by a Gas safe friend all ok. My friend said albeit not common he had seen it before. As a matter of interest has anyone else ever come across a porous iron gas cooker fitting before😕
