Aug 6, 2018
22
Buckinghamshire
DIY or Homeowner
Hi all,
I have a gledhill copper cylinder to fit. It is a direct cylinder containing standard 1'' feed and distribution connections but has the 2 x 1'' connections on the side but no coil in the middle. Can I use blanking plates for these as not required?
thanks
It’d be difficult to tape up with ptfe. I’d be inclined to use a 1” tapered cylinder union and then put a 22mm cap on the stub of pipe.
Reactions: Stigster
I like that idea but the Loctite thread sealing string will do a good job on a 1" thread as well. Either one is a good solution.
Never used this string stuff, it’s about time I got with the times...
But I ain’t using this plastic pipe crap or fitting valliant boilers🙂
Reactions: DGT plumbing
