Just thought to kick this one off - both have their unique properties,; advantages & disadvantages...
Go-for-it... let's hear your arguments, stories etc
tell us more 🙂
Talking of flood damaged Ive been to a job this morning where a failed (full of water) expansion vessel had pulled itself of its wall fixings and then landed on the main return to a 500 liter buffer tank. All piped in copper but if it was plastic it may have flexed a little. I hate plastic by the wayI think the argument against plastic is growing.
I see so many problems with it.
I detest that there are different brands of plastic pipe, each requiring their own make of pipe support.
I also hate the fact that plastic plumbing requires a high pressure test to make the grab rings bite (few ever bother doing this anyhow).
When plastic plumbing didn't exist there wasn't so many homes getting flood damage, due to fittings coming off.
Plastic plumbing is not cheap, although it can make some labour cheaper.
Compression joints on plastic damage the pipe where the olive bites.
Copper is more self supporting and plastic pipe is never straight.
Rodents eat the fittings and the pipe.
UV rays damage all plastic.
If a heating system overheats - the plastic will melt.
Disadvantages of copper are mainly it can corrode in certain water areas and soldering is a fire risk. Installing copper is normally no bother to a decent plumber, but can be slow and difficult to install long lengths of copper below floors etc.
Remember that many plumbers install copper and plastic, but nearly all cowboys use plastic.🙂
A friend had his home flooded by a plastic fitting blowing off the plastic pipe. All fitted by an experienced plumber. Manufacturer said it had been fitted correctly and offered no explanation. We were unaware of the need for a high pressure test to set the grab rings, should this be standard practice? Would normal mains pressure not do this?I think the argument against plastic is growing.
Hey yes, all fill valves for wc's should be brass tailed - how many hours have we spent fixing leaks to the nylon tailed ones... ban them I say.I know this thread is probably meant to be about plastic pipes and fittings, but another plastic plumbing item I hate is plastic ball valves /fill valves on toilet cisterns and tanks. They get hairline cracks. I just replace them with brass tailed valves.
Copper for sure but got too keep whacking in the plastic
Keeps the work flooding in as its rubbish
For sure it has its uses , i heard that over 10-15 yrs the expansion and contraction on the plastic in tight wooden joist holes will wear it away ? Not sure how true that is , but if it is , yrs yrs and yrs of leaks
All pipework should be tested really, for plastic there are two standard tests. I tend to stick with Type A which is fill to 1 bar and wait 45minutes recharging in that time if pressure drops. If no leaks increase pressure to 1.5 max working pressure for 15 minutes then release pressure to 0.5 max working pressure for a further 45 mins. The rationale for the low pressure test is that under pressure, expansion might make a seal hold but with it removed it could open up enough to leak. Always sounded a bit unlikely to me but just to be on the safe side I do it anyway.A friend had his home flooded by a plastic fitting blowing off the plastic pipe. All fitted by an experienced plumber. Manufacturer said it had been fitted correctly and offered no explanation. We were unaware of the need for a high pressure test to set the grab rings, should this be standard practice? Would normal mains pressure not do this?
Which manufacturer of pipe/fitting is this test for?All pipework should be tested really, for plastic there are two standard tests. I tend to stick with Type A which is fill to 1 bar and wait 45minutes recharging in that time if pressure drops. If no leaks increase pressure to 1.5 max working pressure for 15 minutes then release pressure to 0.5 max working pressure for a further 45 mins. The rationale for the low pressure test is that under pressure, expansion might make a seal hold but with it removed it could open up enough to leak. Always sounded a bit unlikely to me but just to be on the safe side I do it anyway.
It's from BS6700:2006 +A1 :2009 ....not that I've looked it up in there, it's just what we were taught in collegeWhich manufacturer of pipe/fitting is this test for?
Reply to the thread, titled "Copper or 'Plastic'...??" which is posted in UK Plumbers Forums on Plumbers Forums.
